tires and gears
Discussion in 'The Garage' started by pennsylvaniaboy, Jan 16, 2007.
  1. pennsylvaniaboy
    pennsylvaniaboy 1/2 ton status
    Jan 28, 2006
    844
    pennsylvania, 15537
    i have '79 1 ton with D60, 14bbt, np205,sm465, 350sbc. i currently have 38/15/16.5's super swamper tsl bias. i am thinking or boggers or rockers because the tsl's dont have the greatest traction i.e. gravel wet grass etc. i havent had them offroad alot due to building it up. any suggestions on tires and who is running them? will maybe go with others.
    i have 38's with 4.10s. i want lower gears so im thinkin 4.56's or 4.88s. i think 5.13s are a little low. i will eventually go to bigger tires so yeh. also what brand of gears and thinkin detroit in rear and wat for the front. i want a locker.
  2. sope
    sope 1/2 ton status
    Jul 8, 2005
    967
    British Columbia
    I have a similar set up and I like my bias TSL's so I have no advice there but for both front and rear lockers I would go with Detroits.
  3. pennsylvaniaboy
    Jan 28, 2006
    844
    pennsylvania, 15537
    rockers
    yeh tsl's aretn bad but thinkin maybe pitbull rockers, anyone run them here? also gear suggestions anyone 4.56,4.88,5.13 any ideas need somethin more thatn 4.10s
  4. barneybasher1010
    barneybasher1010 1/2 ton status
    Sep 25, 2005
    908
    PORTERVILLE CA
    I have 33-13.5-15 Pit Bull Rockers on my Blazer and I like them. Excellent traction and decent road manners. [​IMG]
  5. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
  6. pennsylvaniaboy
    Jan 28, 2006
    844
    pennsylvania, 15537
    yeh
    yeh randys ring and pinion have a great calculator for that. come on fellas help i guy out here need some advice
  7. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    If you are going with a larger tire later I would put 5.13s in now. As for tires I cant help you any I plan on running 42X14X15 Iroks for my rig when the time comes for new tires. And Def detroits for lockers. If you are not going to see much street driving I would weld the rear but for lockers detroits are the way to go.
    Ira
  8. pennsylvaniaboy
    Jan 28, 2006
    844
    pennsylvania, 15537
    how do they run
    alright guys here it is i am gonna run another set of 38's most likely pitbuls, bogger,or tsl's. lockers are gonna be detroits. now for gear ratios. im leaning towards 4.88's or 5.13's. maybe 4.56 if i can be convinced this is whta i want to kno. who runs them and how do they run. i see more md than rocks so gotta be able to spin em good. want good power and good torque too. biggest tires ill ever go is 42's
  9. pennsylvaniaboy
    Jan 28, 2006
    844
    pennsylvania, 15537
    doubler
    one last possibility would be a doubler?
  10. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    just like thay say with lifts go big or go home. go deep with gears or go home.
    all the time and money and you only want 4.56 from 4.10s. thats a wast. you wont even feel much if anything. just go the 5.13 gears and be done with it. then you can also eat rice rides on the street.
  11. pennsylvaniaboy
    Jan 28, 2006
    844
    pennsylvania, 15537
    ok
    ok well i think im gonna go with 5.13's if im worng somebody stop me. and pitbulls for tires
  12. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    you have a 4spd....6.55 is plenty gear. lot of people run 4spd with 4.10s and 38's. if its going to be street driven keep that or go to 4.56. if its not going to be street driven then get 5.13's. 4.88 seems to be people who cant decide 4.56 or 5.13 and they always wish they had gone with either of the other two
  13. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    Auto trans I would go 5.13, but you got a stick.
    Run the gearing thru a calculator and find your best RPM range you want. Small blocks typ like to be run around 2000-2500 RPM cruising, unless you built the engine for a different RPM range.
  14. pennsylvaniaboy
    Jan 28, 2006
    844
    pennsylvania, 15537
    gears
    according to randy's ring and pinion calculater with 5.13's 38's and a 1.00 final trans at 60mph id be turnin 2722 rpm's. with 4.88's and 38's at 60 mph id be turnin 2589 rpm's. what they suggest for rpm range @60 mph for a small block is 1800-2800. i have a 4.3 s10 blazer and its turns up to 3 no porblems. so i dont think that the 5.13s will kill me too bad?
  15. pennsylvaniaboy
    Jan 28, 2006
    844
    pennsylvania, 15537
    any thoughts
    any thought on previous post from those wiser than i?
  16. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    5.13s no doubt, you can just be a bit slower on the highway for the time being.
    I thought the pitbulls rockers didn't come in a 38 yet.
  17. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    ME TOO! :D
    I have 4.56's and 40" MT/R's. I get 14mpg on the highway :woot:and like someone else said the 6.55 low gear is enough gear...especially for mud.
    And to what someone else said about not even noticing going from 4.10's to 4.56's...I did just that in my truck. It made the difference from HAVING to use Low to get the truck going at a green light (without abusing the cluctch) to starting off in 1 like you should for regular street driving.
    I see you're in pennsylvania...If this is your daily driver I would not go to 5.13's...unless you just drive around your little town and the trails are right down the street. My personal suggestioin is 4.88's if this is a truck you will have to get on the highway.
    On a sidenote the fastest I've ever driven (I was not in my truck :haha:) was on the PA TPK...130 m.p.h. and if there was someone going 50 m.p.h in front of me because they realized they should keep they're 350 at a reasonable RPM....I dunno what would have happened :doah:.
