Tires and Wheels
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JROSS, Oct 15, 2001.
  1. JROSS
    JROSS 1/2 ton status
    Oct 12, 2001
    281
    Redding, CA
    I'm new to this Blazer thing and was looking for a liitle help. I am about to purchase an 88' Blazer with little tires and wheels. What would be a good size for tire and wheels for the Blazer which is stock at the time. And if a 4-6" susp. lift was added. Preferably wheels that would work for both setups and tires for the stock setup right now. Thanks for the help all.
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    With a stock K5(stock axles), go with 15" rims due to a hugh nimber of tires sizes availible. You could run 33's with a stock setup, but will be really close to rubbing. I would say 32's for stock but those will look funny when you put the lift on.
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
  3. JROSS
    Oct 12, 2001
    281
    Redding, CA
    What width rim and tire would fit best.
  4. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    my friend did a 4 inch on his blazer, hes got stock rally whels ad 30-31 inch tire and it look hella funny
    high
  5. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    I would go with a 32" tire on a 15x10 wheel (that way after you lift it, you can get a bigger, wider tire and still have a wide enough wheel to accomodate it). You can make 15x8s work also, but I would go with the 10" wide wheels. A 33 will rub some with no lift, so if you want a hassle free ride with a stock setup, stick to the 32s...
    Of course, Blazen91 has been running no lift and 33s for some time, you might want to ask him personally how bad it rubs (if at all).
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I would go 33s on 15x10s stock springs. My friends have done it. On the 80s trucks without worn out springs, they don't rub.
    Tim
  7. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Good to see another drag racer. As for wheels you can use 8" wide rims with 33x12.5r15 with no problem. My buddy runs 33x12.5r15 on 7" wide wheels. I am running my 35x12.5r15s on 8.5" wide wheels. We do this because it keeps the bead protected when we go out rockcrawling. If you dont do rockcrawling then you could go to 10" wide wheels. As for tires I would wait untl after you lift it because 31s on a 4" lift looks kinda funny. I would go woth either 33s or 35s after you lift it 4-6".
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
