Tires: Bigger Better???
Discussion in 'The Garage' started by 1985K20, Jan 30, 2005.
  1. 1985K20
    1985K20 1/2 ton status
    Jan 11, 2005
    191
    Quebec,Canada
    since i find out i got 3.21 gears in my truck, i know 35's are way to big, i was thinking of getting 4 new BF'S mud terrains in the original recommended size wich is LT245/75R16. Will i still get good traction even if they way smaller then the 35's i wanted:confused:
    by the way i know i could change my gear ratio, but the money is a big issue:blush:
  2. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    yes you'll get good traction, and i also think you should stay near the stock size if you arent going to regear, it will make parts last longer and you'll retain the stock power
  3. 1985K20
    Jan 11, 2005
    191
    Quebec,Canada
    Thanks for your message!
  4. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    My truck ran 35's and 3.08's for YEARS (and probably 150,000 miles) w/ a TH350 and a 203. As long as you have some HP, you would be fine w/ 35's on your gears.
  5. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    since you dont have an OD tranny, the gear ratio isnt that big of a deal. you'll lose a little pep around town, but you motor will be happier on the freeway. i probly wouldnt go with 35, but 32 or 33 no problem.
  6. xtrmjoe
    xtrmjoe 1/2 ton status
    Aug 3, 2004
    330
    Boonville, CA
    slap a cooler on the trans and call it good!
  7. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    the 245 will be skinny and short i recomend going to at least a 31x10.5 and i see 3.08 geared blazers run 33x12.5 all the time with no problems
    so i sugest either a 31 or 32 or 33 and not worry aside from a trans cooler witch i belive even an all stock truck needs
    willow
