tires & drive shaft ?
Discussion in 'The Garage' started by 305twistedchevy, Sep 24, 2002.
  1. 305twistedchevy
    305twistedchevy Registered Member
    Aug 29, 2002
    6
    Ocean County NJ
    might sound stupid but i have a 87 k5 all stock but with a 12 bolt my question is what's the biggest tires that i can put on my ride with out hitting right now i have
    32-12.50-15's all around i was wondering what's the buiggest like i said it is stock not looking to lift at this time but will lift in needed
    and also if i put a 4" lift in will i need to lengthen my rear drive shaft any info will thanks
  2. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    It all depends. I've got 33 12.50's on mine with no lift. They only rub if I'm in a tight right turn and the passenger side is flexed up. I don't have a whole lot of tread on mine (A.T.'s) and I imagine if I had swampers I'd be rubbing in about every turn. I have them mounted on stock 15x8 rally wheels which pulls them in and keeps them from rubbing on the outer fender. I don't think you could go bigger without trimming or lifting.
  3. 305twistedchevy
    Aug 29, 2002
    6
    Ocean County NJ
    ok cool i forgott to say my rims are 15-10 steels with 32.12.50.15's thanks for the info
  4. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    I have 35s with a 4" lift. I haven't had to replace my drive shaft, yet, it it is in the plans tho.
  5. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    i have 4 inch lift and 35's no problems.only one is my front driveshaft is a little short.i actually pulled it apart catching a little air out in the desert.i still need to replace that someday.
