Tires - fat or skinny - which do you like?
Discussion in 'The Garage' started by ugly_blazer, Jul 9, 2004.
  1. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    Just wonderin' what you guys think gives more traction in the mud and trails (no rocks around here), a fat tire or a skinny tire? I used to think that the fatter the better but now I'm wondering if maybe skinny isn't better. I've seen some trucks blast through mud with skinnies where the fat tire trucks would just sit and spin.
    What works for you?
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    A tall and skinny tire for snow, so it makes more weight in one spot, you just need momentum.
    Or really wide agressive tires for mud. You may see skinnier tires in the front for less resistance, and better steering.
    For me, it's going to be wide at every corner /forums/images/graemlins/pimp1.gif
  3. nova
    nova 1/2 ton status
    Mar 9, 2003
    285
    Laporte, IN
    go with skinny , it has less drag, narrow width to fit in tight places, & usually a cheaper tire. i run 39.5x13.5x16.5 irok's on 16.5x9.75 mickey thompson classic 2 rims with 4.75" back spacing. /forums/images/graemlins/waytogo.gif
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    36x14.50x15 Ground Hawg 2's is what I went with. /forums/images/graemlins/waytogo.gif Very aggressive, and will last along time even with street usage. /forums/images/graemlins/deal.gif
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i think it depends on what type of mud, clay, soupy, swampy.
    clay is some nasty [darn], you need all the surface you can get - wide
    soupy you want to dig down to the solid ground underneath - skinnny
    swampy mud you want to help float on top - wide
    these are my opinions, im going with a 14" wide tire.
  6. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Pontiac said it right "Wider is better" I run 90% mud and once in a while I'll find a spot where there is no solid bottom. I need the wider tire to float across the top to make it without sinking like a rock. If I had a narrow skinny tire and tried to dig through to the clay on the bottom I'd bury myself to the doors before I found anything solid. There's a lot of clay around here though, it's nasty stuff so you'll want a very aggressive tire with large voids and lots of surface area. /forums/images/graemlins/waytogo.gif
  7. dyeager535
    26,975
    I would agree. *If* you can get down to a hard surface, skinny tires are the way to go.
    All you have to do is hit a large puddle on the road at high speed with both a wide and narrow tire to know which one works better in that kind of situation.
    Of course tread pattern is just as much of a factor, but equal tread, thinner tire for getting through to solid ground.
  8. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    All I have to say (and it may have been said before) is:
    Skinny tires are easier to steer
  9. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Thats what I said /forums/images/graemlins/smirk.gif
    But also if you use skinny tires to try to find solid ground underneath, sometimes there IS NOT a bottom /forums/images/graemlins/yikes.gif
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    no one that replied to this thread has enough power to "float" with a wide tire
    tall is more important then wide any day
  11. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    what i want to know is...will 2 inches more in width really make a tire magically float over mud, instead of "sinking to the bottom" and "finding traction" ?
    Skinnier tires all the way.
  12. mcinfantry
    mcinfantry 1/2 ton status
    Dec 2, 2003
    308
    skinny. i ran LBL, kentucky with skinny tires, and went everywhere the fat tires went. matter of fact i didnt side slip like wide tires do in the mud. i tracked straight and have lockers front and rear. i also didnt slide off camber like they did.
    i run 11" wide 38.7" michelin xl tires. (1100x16)
  13. diesel4me
    Jul 24, 2003
    17,537
    923
    Massachussetts
    I can only relate my experience with snow,since I dont do much wheeling here--tall skinny tires work best in the snow.I often have to help extract some other plow rigs from parking lots when they charge in for the first pass after a deep snowfall--lots of guys have 33's or larger and wide tires,and they float on top of the snow and the truck wants to jacknife instead of pushing the snow.It really ticks them off to be pulled out by a rotted old GMC with stock tires /forums/images/graemlins/grin.gif(mine are now 245/75/16--used to be 8.75x16.5)and they are all season ,and only have less than 1/2 tread on them.I guess they thought all that money spent on tires and rims was going to insure they never get stuck--wrong!! /forums/images/graemlins/blush.gif I can plow until the snow comes over the hood and I cant see,the wide tire guys have to back up and "batter ram" the snow,and end up going sideways after about fifty feet,while I can just plod alond at about 10 mph,in a nice straight line--I put about 1500 lbs of sand in the back most of the time (to spread around after plowing)but even empty I can outplow the guys with wide tires and weight. /forums/images/graemlins/whistling.gif
  14. ugly_blazer
    Apr 12, 2004
    1,214
    I think I will stay with the skinny tires also, if not for more traction just for the extra stability factor, they let me steer better.
  15. duece21
    duece21 1/2 ton status
    Jan 18, 2004
    501
    Aurora, CO
    I have done alot of florida mud in my days there and the tall skinny's beat out the fat boys every time. Tread aggresiveness helps too.. Look at tractor tires. Those things are as tall as the tractor itself.
  16. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Sounds like snow is the closest thing to the tread clogging mud we have got down here! Tall skinnies beat wide almost everytime, when you get a 500 or so horse BB spinning 44's I think its different, the tires and rig then weigh alot more but for practical tall skinny's
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I used to love skinny tires, but the first time I stepped on the throttle with lockers in both ends and 16" wide tires I was instanly hooked on wide tires. Nothing beats the traction of a 16" wide tire at 10 PSI without wider tires or beadlocks in my opinion.
    For rocks it doesn't seem to matter, but for mud, there is NO substitute for wide tires unless you're playing in a farm field instead of a mud pit.
  18. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    You skinny tired guys haven't played in mud bogs very much have you? Unless you have a VERY tall tire with at least a 15 inch wide tread (think 42x15 TSL's) you're going to knife your way through to the surface below. Sometimes there may be traction there, sometimes there might not. Yes, you can steer better with a skinny tire, that's the same reason snow-mobiles put ski's in the front and a huge track (as wide and long as possible) in the rear to keep the thing ABOVE the frozen ground underneath. If you're in mud deeper than the amount of ground clearance you have (not much if you've only got 36" tires) then you need a wider tire to keep you above China. /forums/images/graemlins/ignore.gif
  19. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    i argee a skinny tire it good for snow on the road.
    i lived for 5 years where we got 300+ inches of snow a year, and the widest tire with the least amount of air was the ticket for off road trips. there was no way you could find bottom without being buried in 4 feet of the white stuff. horspower didnt matter, gearing did since the snow has to pack under the tires to go anywhere.
    there is a difference in a couple of inches in width, especially then you start deflating the tire. a wider tires has a larger foot print hands down.
  20. MR4WD
    MR4WD 1/2 ton status
    Jul 28, 2002
    133
    Fort McMurray, Alberta.
    I'm all about the wide tires. Up here you certainly can't dig to the bottom, so you might as well try and float.
    My boggers are plugged solid, but that's from digging in to pull another guy out.
