tires how much weight is to much
Discussion in 'The Garage' started by meanmudder, Apr 12, 2002.
  1. meanmudder
    meanmudder 1/2 ton status
    Feb 27, 2002
    128
    Cleveland, Texas zip 77327
    42-15-16.5 ss two tires took 32 oz of weights
    1 tire took 33 oz of weights and 1 tire took 10 oz of weights
    3 tires bad ??
  2. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    what kind of tires?
    my 36" swampers took up to 7oz
  3. meanmudder
    Feb 27, 2002
    128
    super swamper tsl
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    that is the exact reason most folks dont bother to balance them(tires larger than 38'') all the way.
    they cost a lot to balance and take a long time. and use off road weights do not always last that long. so it can be a consistant fight to not vibrate.
    grant
  5. meanmudder
    Feb 27, 2002
    128
  6. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Was this on brand new tires that had never been run before? If so, they were probably flat spotted real bad. If you want to try and get a decent balance on them, I would drive the truck a bit, then right before they are balanced, drive it for a few miles to make sure the tires are up to operating temperature.
    I tried balance powder in mine with minimal success. I'm gonna try 1/2 dozen golf balls in each tire next. I suspect part of my problem is my beadlocks, though.
    Swampers also chunk pretty bad when used hard off road, making it hard to maintain good balance using conventional weights. Plus most of them are square.
    Pete
  7. ibrakeformud
    ibrakeformud 1/2 ton status
    Jan 8, 2002
    118
    vancouver wa
    there is the powder balence and there is a liquid balence i worked at bruces tire in fremont and all all semis or off road tires we would use the liquid balence it also stops rust from forming. it works pretty good but cost 25 bucks a bottle and for those tires it would take 1 each just my .02
  8. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    my 39 boggers took:
    18 oz
    22 oz
    25 oz
    and last but not least......36 oz
    that last one is running on the left rear...my buddy owns the shop that i got em from so im gonna go back after i put some miles on them and get them rebalanced.
    Later
