Tires/lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89Blazin, Jun 18, 2001.
  1. 89Blazin
    89Blazin 1/2 ton status
    Mar 20, 2001
    134
    midwest KC area
    Anyone runnin 15 inch wheels w/ 33X12.5s without a lift? If yes, are there any clearance issues?
    85 Burb and an 89 Blazer
    One just for fun, one simply for pleazer
  2. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Right now I have 32x11.5s on 15x10 Eagle rims without a lift. I do get rub on the front fenders when the suspension becomes even slightly compressed. I am installing the Rough Country 4" front/rear spring lift on mine this coming weekend. That should clear me up to 35" without too much problem.
    85 GMC Jimmy, 305 w/TH700-NP208, 32X11.5 BFG ATs, 15x10 Eagles, Smittybuilt tube nerf bars and bumbers
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    what offset are the rim's? i have 33x12.5x16in tires no lift and do not rub but i have a positive offset if i had a negative offset they would rub when articulating(sp?)
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>
  4. Jonathan
    Jonathan 1/2 ton status
    Apr 14, 2001
    293
    Little Rock, Arkansas
    I was wondering the same thing, Would they work OK with my stock rally wheels and no lift?
    77 Blazer, 350, NP203, K&N, 31-inch Cooper Discoverers
    <A target="_blank" HREF=http://www.Jonathan.coloradok5.com>http://www.Jonathan.coloradok5.com</A>
  5. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    I ran 33.12.50.15's on my 15 x 10 inch rims for 2 years and they worked great. Just a little bit of rubbing when i was getting loose. Go big...
  6. 89Blazin
    Mar 20, 2001
    134
    midwest KC area
    Thanks to all for the replys. I have 2 inch blocks front and rear, bought it like that, and know blocks up front are a hazard. So.....until I save enough nickels and dimes to do the front right, I was contemplating removal of the blocks.
