Tires size recommendations???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cryptobiotic, Jan 8, 2003.
  1. cryptobiotic
    cryptobiotic Registered Member
    Dec 31, 2002
    53
    Utah
    I have a 4' Rancho lift, i am planning an axle swap soon, i was wondering if i can fit 38' tires underneath with a 4' lift?? I was going to go with new 35's but i was wondering if anyone has anything bigger than 35's on a 4' lift, and how much fender cutting do you have to do?? /forums/images/graemlins/k5.gif
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> You should be able to fit 38s easily under a 4' lift. Now, a 4" lift is a different story. /forums/images/graemlins/grin.gif You could probably squeeze em in there with lots of cutting, have to trip back to the firewall and pound the body seam flat to minimize it as much as possible. If you run the narrow 38s then it would be a bit easier. /forums/images/graemlins/thumb.gif </font color>
  3. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    I got 39.5's on a 4" lift,they are on 8" wide rims.Alot of cutting,but with patience you can make the cuts look factory.Also I run no front wheelwells,and longer front springs(moved the diff forward 1/2").
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i run 38's with only 2.5in lift so yes you can fit 38's with 4in lift /forums/images/graemlins/smile.gif
  5. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    4'
    48"
    Wow, I think the only legal way you can run that much lift is if you put 44s on 10 bolts and run 6 chrome shocks per side (federal regulations.)
    It depends on how much you like your fenders the way they are. If it's a rust bucker, chop them to bits and fit the 38's. If you can't stand the thought of that much cutting, get a 6" and you won't have to cut nearly as much.
    -- Mike
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I wouldn't go bigger than 35s myself, hate non-functionality and I think if you can't articulate much or travel through half your suspension without contacting something its just stupid. And yeah you can remove inner fender wells and cut fenders but that looks like crap to me and makes it quite easy to cover your beautiful hard working v8 beast with mud :-/ thats not very nice of you.
  7. DaveCowley
    DaveCowley 1/2 ton status
    Feb 18, 2002
    196
    Provo, UT, USA
    On 4 inches No Body Lift mine should fit 39.5's fully articulated. I haven't bought the tires yet but with my 35-15.5 TSL SXs fully turned and stuffed I am 2.5" from hitting anything. With inner fender wells still protecting the engine. I had to cut the back of them off though. I have my shocks in stock location up front with 5112s out back in custom locations but it ramps over 700 rti on a 30 degree ramp so you can clear 38's and still wheel your rig expecially the 38x13x16 TSL's. That is the size I like.
    Dave Cowley
  8. K5on38s
    K5on38s Registered Member
    Dec 11, 2002
    90
    Buffalo, NY
    Well im running 6" of lift and 38.5x16x15 and i got about 2-3" between tir and the wheels wells w/o cuttin so if you dont wanna cut anything you prolly wanna go to 8...but youll prolly rub under heavy articulation
  9. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    hey i have 38's and only 2.5in lift and still have my iner fenderwells and can MAX OUT a 23 degree rti ramp without hitting anything /forums/images/graemlins/shocked.gif why lift it sky high and make it more top heavy when you dont have to? look at my pics and tell me if you think it looks like sh!t /forums/images/graemlins/shocked.gif
  10. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    i agree why go top heavy ! do the 4inch like you want and cut to fit 38's maybe even 37's /forums/images/graemlins/ignore.gif /forums/images/graemlins/smile.gif
  11. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I looked at your pic's and the only thing I'll say is whats up with the ugly wheels /forums/images/graemlins/ignore.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/grin.gif
    But for the record I'm running a 2.5 with a 1in body and 35's I've been thinking of going to a 37x12.5r17 so your truck has given me hope that it will fit just fine. And yes the fenders are cut.
    Eric
  12. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    hey i needed 8 lug wheels and they were free so i couldnt pass them up lol ya you can fit 37's if not break out the sawsall /forums/images/graemlins/thumb.gif
