TIRES???
Discussion in 'The Garage' started by AZ85JIMMY, Jul 24, 2002.
  1. AZ85JIMMY
    AZ85JIMMY Newbie
    Jul 23, 2002
    I just bought an 85 jimmy with a 4" inch lift and im looking for tires that can take some off-road abuse but not too agressive tread because it will be a daily driver. Im looking at the baja claw radials or mud terrain's, what do u think? Also im looking to run 35's but i don't want to deal with fender trimming. Has anyone squeezed 35's with a 4" lift without the tires rubbing???
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Let's see..
    Baja claws = SUCK!
    Bfg mudder's = Good choice!
    Seen alot of peeps go with 35's and 4" of lift. It can work unless you do some flexing.
  3. Range Boy T
    Range Boy T Registered Member
    May 2, 2002
    21
    U.P of Michigan
    Go with the BFG Mudders. I have the AT's on mine for road tires. I had a 4" lift on mine. Most playing around i was good untill i really flexed the front then it rubbed. But some minor fender trimming would do the job.
  4. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    I have to disagree with you UseYourBlinker. I've had my Baja Claw radials for two years now and they're still not worn out, even with shot balljoints. My truck is a daily driver and they haven't failed me yet in sand or rocks. Now as far as mud goes, you might as well stop while you're ahead cuz these things don't grip for $h!t. Like they said, 35's will fit with minor trimmage.
  5. UseYourBlinker
    Jun 7, 2000
    11,117
    That's why I said they suck! /forums/images/icons/grin.gif
  6. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    35s will fit with 4" of lift so long as your sway bar is connected. I only rubbed mine (and procomp muds are very close to nominal size) when I went disconnected. Even with a flexy front end tho, a little trimming solves the rubbin' problem.
    AFA tire brands go, IMO the best all around 37" and under off road tire is the MTR. I have ProComp muds, good on trails and rocks... and quiet on the road. MTRs are better than mine in mud.. a shade better on rocks too I bet... a little louder on road, but who cares. /forums/images/icons/smile.gif Claws are over rated IMO, spendy to ain't they?
    J
