tires...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by yellowk5, Sep 16, 2002.
  1. yellowk5
    yellowk5 Registered Member
    Jul 24, 2002
    11
    i have an 89 with the stock rims that have 31x11.5 now. i was wondering if 33 or 35x12.5's will fit. also, please lemme know about places to get good deals on a set. i am in orlando, so newhere in that area would be great. thanx guys
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    You mean fit on the rims or under the sheet metal?
  3. yellowk5
    Jul 24, 2002
    11
    both...first off would the 12.5 fit on the rim and would a 33 or 35 fit the well. i dont have a lift...everything is stock for now....sorry about the confusion
  4. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    If you stay on the stock wheels and you don't wheel it very hard, you can fit the 33x12.50's with some minor rubbing/trimming on the front fenders. No way on the 33's with anything wider than an 8" wheel on stock suspension/sheet metal. No way on the 35's period unless you lift at least 4" and stay on the 8" wheels you can fit 35's on 10" wheels with some front fender trimming and a 4" lift. If you don't want to trim at all, and use a 10" wheel, then you need 2 1/2" - 4" of lift for the 33's and at least 6" lift for the 35's. AFA where to buy, it depends on what you're looking for. America's Tire seems to have the best deals on the BFG KM's and AT's. Hope that helps some. /forums/images/icons/smile.gif
  5. dyeager535
    26,978
    Yeah if you don't wheel hard, but need the slightly better ground clearance and look of fuller wheel wells, BFG's 33x10.5R15's fit stock wheels no problem, and TYPICALLY clear the body in all conditions. (I'm talking stock suspension here)
  6. sdavid
    sdavid 1/2 ton status
    Aug 5, 2002
    244
    Livingston, TX
    Summitracing.com has good deals on Pro Comps right now. About $112 for 35x12.50x15 MTs, less for 33s and 31s. You might want to check it out. There are also different widths of stock wheels (ie: 15x6, 15x7, 15x8). Check the sticker on your driver's side door.
  7. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    running 33 12.50's no lift 15 x 8 rims
    only made it rub once ditch crossing 45 degeree angle turned the wheel to the stops and hit another bump in the narrow ditch, and had a minor rub
    my wheels are not stock, but are stock size
  8. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    The tires will fit the wheels no problem. As for fitting the wheelwells, the 33's will fit unless you really get it crossed up. I ran 36x12.50 TSL/SX's on stock 15x7 wheels with NO lift. I cut the front of the fenders some and beat the lip back on the rear of the fender opening. It fit with no problems.
