To AC or Not To AC
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by newGenk5, Sep 30, 2001.
  1. newGenk5
    newGenk5 Registered Member
    Sep 14, 2001
    36
    Sacramento, CA
    i've got a 72. is it worth keeping the AC compressor even though the truck is a full convertable. are there any benefits to keeping it at all. what is the key benefit to removing it other than more power.
    thanks
    keep on rollin
    <a target="_blank" href=http://64.172.156.16/k5>check it out</a>
  2. SilverJim
    SilverJim 1/2 ton status
    Sep 23, 2000
    105
    Evergreen
    is it factory a/c?
    1970 GMC Jimmy 502HO/SM465/NP205 doesn't run just yet!
  3. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    The key benefit to removing the A/C is less weight (about 108 pounds). The drawback to removing it will be the ugly holes in the dash and a sweltering hot interior on hot days (my Blazer is non-A/C and I am planning on putting A/C onto it, but I'm missing a few parts).
  4. newGenk5
    Sep 14, 2001
    36
    Sacramento, CA
    the ac is factory ac.....but i never have the top on uless its is raning or winter....i live in sacramento, CA so the weather here is always hot.....and the top is 90 off year round.....
    keep on rollin
  5. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    you can convert it to onboard air, thats what I plan on doing and others have done it also, do a search someone did a write up on it....[​IMG]
    <font color=blue> I'd rather have a bottle in front of me, than a frontal lobotomy!
  6. newGenk5
    Sep 14, 2001
    36
    Sacramento, CA
    what exactly is "onboard air" there are not too many pioneer's here. if you dont mind explaining what is it...
    thanks
    keep on rollin
  7. chevyfumes
    Feb 24, 2000
    38,584
    266
    You know an onboard air compressor, you use the compressor and get yourself a storage tank and you can use it to fill up your tires or run air tools or fill up rubber rafts things like that [​IMG] if your interested I think I saved the info on how to do it...[​IMG]
  8. Dave_S
    Dave_S Registered Member
    Apr 11, 2001
    56
    Portland, OR
    What parts are you missing Steve? I probably have them.
    Dave
  9. newGenk5
    Sep 14, 2001
    36
    Sacramento, CA
    yes please.....i would totally appreciate that.....i would of never even thought of that......very cool....
    keep on rollin
  10. chevyfumes
    Feb 24, 2000
    38,584
    266
    go to 73 to 91 and do a search on (air compressor) and you should find some stuff. Or post it on there and someone should give you a write up on it. I'll look for the one I found too...
  11. Steve_Chin
    Mar 6, 2001
    1,126
    Dave, I'm missing the control unit (and vacuum lines), control cables, center air outlet, and the brackets that go between the compressor and the water pump and between the compressor and intake manifold.
