To add or not to Add (a leaf)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by foxman, Nov 12, 2001.
  1. foxman
    foxman 1/2 ton status
    Oct 22, 2001
    251
    Detroit MI
    My front leafs are nearly inverted at rest. Are they supposed to be like that? Would adding a leaf help to restore the "natural" U shape in the leaf spring? The front is sitting a littlr lower than the rear. Would this be a good thing to do? Thanks for the responses>>>>.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If your truck is stock height, I think it is supposed to be like that. Mine was on my Jimmy. The only real way to solve the negative arch is a lift kit.
    My Chevy isn't broken, its just out of gas.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Yup thats is the way they are susposed to look. The front springs have a negative arch They should be level or slightly inverted at rest.
    You are lucky the front sits lower than the rear most K5s suffer from saggy butt syndrome.
    A new set of springs may help to level it out if the fronts are wore out. Or as said you can go with a lift.
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze>http://coloradok5.com/gallery/Thunders-Blaze</a>
    <font color=blue>NEVADA: Where the pavement ends, and the West begins.</font color=blue>
