to all rear disc brake conversion folks, PLEASE READ
Discussion in 'The Garage' started by milspecjimmy, Mar 15, 2003.
  1. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    i am looking into putting rear disc brakes on my jimmy, and also will be putting a new master cyl on it in the mext few days. i know that disc brakes require a lot more fluid and i know that i have a small rear resivour on the current master. my Q? is, is there a master cylinder for a vehicle with 4 wheel disc brakes that will fit my truck? and would there be any bennifit? just currious, i AM CHANGING IT because it died on me, so if i can up grade then now would be the time
    thanks
    ~~~jeff
  2. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    I used one on my 87K5 that was spec'd for a 1 ton 89-90 GM truck/Van with 4 wheel disc brakes. Went to NAPA with my old MC and went thru their book until we found a 4 wheel disc brake MC that had the same bolt patterns and connecting points/threads. Cost me about $126
  3. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Im using the stock style master cylinder. Just gut the proportioning valve like grimmy did on the write up.
  4. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    yeah, uhhhh /forums/images/graemlins/rolleyes.gif i already have to change the master, so i want to get one that will work with the current system. rather than buying the same master, and changing something else, i want to get teh the master best suited for this application without having to do it and every thing else. it just makes sense to me since i have to change the master any way
  5. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    You may still need to change the proportioning valve as the one on there now is designed for disc/ drum brakes not disc/ disc. So if you want to do it "right" you should change it too.
  6. jackedjimmy
    jackedjimmy 1/2 ton status
    May 18, 2002
    195
    Redmond WA
    89-90 1 ton trucks/vans had rear disc brakes?
