to anyone using trailready beadlocks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BOWTIE, Oct 28, 2002.
  1. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    with the 16.5's
    what size of tire and what pressure do run on the trail? also have you had problems with the inner bead popping off at low air pressures?
    thanks
    ric
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    I have asked this question before also. Stephen Watson runs them down to about 6 PSI with no inner beads off IIRC. I think Steve fox has them also but I don't recall how low he goes. I have not read of anybody loosing an inner bead with the Trailreadies.
  3. CK5
    May 19, 1999
    21,623
    701
    CO
    I usally run around 10 PSI on the trail, good balance between tire flex and ground clearance, drove them on the street once with 4 PSI with no problems.
  4. BOWTIE
    Dec 28, 2000
    2,018
    thanks for input....
    do these wheels have that safety bead lip on the inside so the tire doesn't pop off?????
  5. CK5
    May 19, 1999
    21,623
    701
    CO
