To Detroit or spool . . . . . .
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by spaceboy, Mar 14, 2002.
  1. spaceboy
    spaceboy 1/2 ton status
    Jan 14, 2002
    106
    Pearl City, Hawaii
    I'm looking to replace the limited slip in my front Dana 60 with a full locker. It has served me on trails but I just don't like the word limited in there. I already know the pro's and con's of a front locker (under steer, greater turning force required) I am just trying to consider my options here. Will a full locker even affect street drivability if the hubs aren't locked in?? Arbs are nice, but they are expensive and I have heard that the fittings do leak air sometimes rendering them useless. Any input from someone with a front locker will be greatly appreciated. Thanks.
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    I've got a Detroit in my D60. Yes, it does increase turning diameter but in my experience it has not been a big problem. Maybe on a tight trail it would be (almost for sure it could) but that's when I'd drop it out of 4LO to 2HI, make the turn and drop it down again. Worth it for the positive traction. JMHO
  3. smartpatrol
    smartpatrol Registered Member
    Feb 6, 2002
    86
    Ault CO
    Another thing you might consider is the new magnetic lockers from eaton. I haven't seen a whole lot of information on them but i plan on using them for my front dana 60 when i get to that point.
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    If you go w/ a locker it won't lock up if you don't put power to it. You could twin stick your case (if it is a 205) and drive in 2wd till you need the traction. You would be able to steer just like you had a open diff.
    If you go w/ a spool you will have to unlock a hub to turn. Not fun unless you have a passenger that don't mind doing it all the time.
