To do a 1inch body lift or not.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87GMCJimmy, Mar 5, 2002.
  1. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    I'm replacing the drive train on my Jimmy and in the process pulled the radiator support out. The stock rubber body mount bushings looked like crap and the bolts where severly rusted. I thought this was weird because the rest of the truck is pretty much rust free, but anyway onto the point. I'm going to replace the body mounts with poly and considering the ORD 1 inch lift. Are there any other modifications that require the 1 inch body lift, such as installing a doubler? Are there other performance modifications that you can make only after installing the body lift?
    Mike
  2. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    No worries! Install it and go! Combine it with your 4" lift and you could run 33's w/out rubbing. You could run 35's on an 8" wheel if you don't wheel too hard, but you may have to trim the front fenders a bit.
  3. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I'm going to replace my bushing's,and also install the 1"body lift. Might as well do it while your under there. I got the lift,but still need to order the bushing's /forums/images/icons/smile.gif Grimmy,and Steve are doing a write-up as we speak. On the install of the body lift and bushings. One mod is adjusting the linkage for the tranny.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Consider a 3". If you're going to body lift it, you might as well go the whole 3".
  5. Greenblazer-AZ
    Greenblazer-AZ 1/2 ton status
    Jan 4, 2002
    770
    Chandler, AZ
    I did it. I'd reccomend it. Be sure to check out my post: "Just finished lifting the body". You may find it very helpul.
  6. Big Muddy K20
    Big Muddy K20 Registered Member
    Dec 12, 2001
    17
    Sonoma, CA
    I contemplating a body lift when I get my 39's, I'm no stranger to the sawzall but I think they might fit a little better with the body lift, I'm in the process of making new inner fenderwells that go all the way to the cab and almost up to the hood so I can stuff the tires and still keep my motor kinda clean
