To kick it off
Discussion in 'The Garage' started by TX Mudder, Mar 5, 2002.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    What do you guys think about a 6" susp. lift and 35" tires?
    I have been really wanting the 37" SSRs but they are more expensive and I think they'll hit the fenders. Body lift is out and so is hacking the fenders - just put two new Goodmark fenders on.
    -- Mike
  2. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Forgot to mention I have the ORD front shackle for extra 1/2" front lift.
    If absolutely needed, I could go for a 1" body lift or 1" zero-rate. I'm happy with the height at 6" give or take.
    I'd probably go for 35-12.5-15 Pro Comp Mud because I'm cheap. 4WPW is bound to have a buy 3 get 1 sooner or later.
    -- Mike
  3. CK5
    May 19, 1999
    21,627
    704
    CO
    I think you would be fine, I used to have a 4" lift with 35's, it rubbed a little but with 6" you should be fine with no trimming.
  4. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    I run a 6in BDS all spring and ORD shackles to clear the 37 SSR's...with daily driving and curb hopping you'll be fine, but when you start offroading and bounce around, thats when you'll start re-doing sheetmetal...ending up measuring 8.5 inches from the door and cutting to the top of the wheel well, sorta like the UAV, its plenty to clear the meats.
  5. Grim-Reaper
    7,385
    Atlanta
    I'm about to throw 35's on with a 4 inch lift. Depdog is clearing 36's on 10 inch rims. He has done a lot of cutting to do it.
    I scrub 32's now on 8 inch factory rally's but it's hitting up where the two bolts are that hold the inner fender to the fire wall. It just touches enough to scrub the dirt off and make a pop on the heads of the bolts. THis is when I get full lock on the steering.
    I'm trying something different to address the clearence issue. I am cut back flush to the inner fender and hoping not to need to cut anymore. I did a one inch ORD body lift and going to move the front axle forward 1 inch with the ORD Zero rate offset Add-A-Leafs. We will see how that does. I'll be running 10 inch wide rims with 4 inch offset.
  6. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    well, i'm running 4" lift and 38" tires..... some trimming required i guess...
    :haha: is there a smiley with a long beard and white hair? not santa...
