to much tranny fluid????
Discussion in 'The Garage' started by little79k5, Jul 3, 2002.
  1. little79k5
    little79k5 1/2 ton status
    Mar 27, 2002
    230
    panama city, fl
    suppose i had to much tranny fluid in my th350. would this cause it to leak anywhere??? like where the linkage goes in? any expierences??
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    if you over fill it it will start to spit it out the vent tube /forums/images/icons/shocked.gif
  3. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Yeah its called chassis lube /forums/images/icons/grin.gif
    If your vent tube is plugged the pressure could blow a seal out somewhere /forums/images/icons/frown.gif
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    if you overfill it it will build up pressure and probably blow seals.linkage i think is only an oring to seal it.its been a while since i had an automatic.it could also come back out the dipstick tube when the pressure builds up.
