To prime or not to prime?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mike87, Dec 10, 2001.
  1. Mike87
    Mike87 Registered Member
    Feb 18, 2000
    20
    San Jose, CA, USA
    I am finishing the install of a new GM crate motor and am wondering if it is necessary to prime the oil system or not? I have heard many +/- and am confused. Other motors that I have built and installed I have just cranked the motor until I get oil pressure (without starting) then once oil pressure is good, I proceed to start the motor. Is this an acceptable way to do a GM 350 or do I need to use a primer?
    Thanks for the input,
    Mike
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I'd prime it. Im sure they use assembly lube but it only takes a minutes and it gaurantees that oil is where it's s'posed to be. I'd hate to burn a bearing or a cam lobe!
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  3. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Going back and looking at your post....... I've seen people pull the plugs and crank a motor but it's still a "dry start".
    Jim
  4. 77JimmyMan
    77JimmyMan Registered Member
    May 16, 2001
    29
    Southeastern MA
    Dude you should prime it before you try to start, something you should do to if the truck/car has been sitting for a long while also. If you just crank it to prime your running the bearings dry for that split secound or so it takes to build oil pressure. It could cause some problems even with everything coated in assemble lube. So ya Id pime it to be safe, just think of how much time it takes to prime a motor versus trying to put in new rods and mains (bearings).
  5. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    Rookie question: Can someone please explain the process of priming an engine? I'm getting ready to drop in my new crate and this info might help.
    Rod
    Alameda, CA
    85 K5 6"ProComp 35"Boggers 14Bolt/ Dana44 4.10's
    <a target="_blank" href=http://coloradok5.com/gallery/K5Jungle>http://coloradok5.com/gallery/K5Jungle</a>
  6. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Your distributor shaft runs your oil pump. Basically you remove your dist. and use a special adapter and a drill. Stick it into the oil pump and prime the engine. I dunno what direction it turns tho'. As far as I know you can buy these at any parts store or even cut a flathead screw driver.
    Jim
  7. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    Definitely!! I have never heard of any negatives about priming an engine's oiling system prior to startup, but am always open to hearing/learning anything new.
    The adapters are not too expensive, but if you have an old junk distributor laying around, you can make your own by removing the shaft, cutting off the top of the shaft and housing, reinstalling the shaft in the housing and spinning it with a drill.
    When you do prime it, have a buddy slowly rotate the engine a few times while you spin the priming tool with your drill. This will allow all the oiling holes in the crankshaft to temporarily line up with the oiling holes in the bearings/connecting rods and really get a good coating of oil on all the friction surfaces. When you're done, reinstall your distributor and spark plugs and fire it up.
    All in all, much better than dry firing your new engine; at least IMO.[​IMG]
    Robb
    '73 GMC Suburban - 502DFI
    <a target="_blank" href=http://community.webshots.com/user/robbrj>community.webshots.com/user/robbrj</a>
  8. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    remove the gear off of an old distributor
  9. 502Burban
    Jun 8, 2001
    379
    Southern California
    Thanks for catching that one for me, Michael. I forgot about removing the gear.[​IMG] That could be ugly![​IMG] Guess I better type a little slower and think a little faster next time.
    Robb
    <a target="_blank" href=http://community.webshots.com/user/robbrj>community.webshots.com/user/robbrj</a><P ID="edit"><FONT class="small">Edited by 502Burban on 12/10/01 06:28 PM.</FONT></P>
  10. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    WHAT!?! Your kidding right? Gotta prime it... I dunno who said it is bad or whatever but they are flat out wrong! In fact if you don't GM will void your warranty. You must break gm crate engines according to GM specfications or your warranty will be voided. The procedure should of came with the crate motor or I know you can get it off the Jim Pace web page.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  11. lasvegas
    lasvegas 1/2 ton status
    Feb 27, 2001
    122
    Las Vegas, Nevada
    what direction do you turn the pump or does it matter when you are priming???
  12. Innerpiece
    Innerpiece 1/2 ton status
    Feb 22, 2001
    145
    Mississippi (Yee Haw)
    You must turn it the same direction as the distributor rotates.
  13. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    You turn it clockwise.
    The priming tool is only $10 or $15 and it will hook right up to your electric drill. Put the drill on forward and away you go.
    Yes, have a friend turn the engine over with a braker bar on the 5/8" bolt on the harmonic balancer while you prime it. I think I'd prime it a good 15 or 20 minutes just for safety.
    -- Mike
    <font color=blue> Married to a woman who understands the need for <font color=orange>Hugger Orange. [​IMG] <font color=blue>
