To rebuild or not to rebuild (Tranny)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lehtola, Mar 30, 2001.
  1. lehtola
    lehtola 1/2 ton status
    Mar 21, 2001
    192
    North Carolina
    I was wondering. For those of you out there that have done this. I'm having problems with my overdrive (I hear a light metal clanking) when I'm cruising along and accelerate a little. Not too much to make it shift but just a bit. Things are fine if I just keep it in drive but OD you can definately tell. My question is...How difficult is it to rebuild a 700R? Supposing I wanted to put the best components in it...like the flywheel and pressure plate...and a better piston...oh...and a shift kit.
    1990 GMC Jimmy 350/TH700R4/NP241/10 bolts, 4" skyjacker lift, 35x12.50R15 BFG All Terrains on 15x10 AR Baja's, Flowmasters.
  2. dyeager535
    26,979
    If you've got time, space, tools, and the money, no reason not to do it yourself. I did 350's and 400's before i tackled my first OD tranny (200-4r) because I was scared what everyone said about how hard OD trannies were and such. No big deal, just a few more parts. Nothing real complex about disassemble/reassemble, just some specialized tools make it easier. Personally, making friends at a local tranny shop is cheaper than buying the tools : )
    Dorian
  3. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Its not bad, just be sure to keep everything clean and remember what order everything came out.
    Will work for beer, parts and tools.
    90 Jimmy 350TBI-700R4-241-33" BFGs-10 bolts w/4.10's
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
