To rebuild or not to rebuild?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89GMCSuburban, Jan 28, 2002.
  1. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I can get a complete long block for $635 with all cast stuff. Well, my question is, after they torque down the main and rod caps, can you undo them without messing up the bearings? I found a set of Hyperteutic flat top pistons for $101 and I was thinking that I could get the pistons, take out the rods and get the new pistons put on, and then re-assemble it. Can I do this???
    Red 1989 GMC Suburban SLE V1500 - TBI 350, 700R4 w/ shift kit, Quad-shock front, 31/10.50/15 Pro Comp MT, 4.10 gears, Duals off cat
  2. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    My two cents worth would be why bother ? First off do you really need Hyper. Pistons? If this motor is just gonna be a mild buildup then I would say just keep the stock stuff, otherwise if you really want the better pistions then get them and just get a 350 block done up as it will be much less of a hassle IMO.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  3. Gold Rush
    Gold Rush 1/2 ton status
    1,498
    Yes you can do that but if you'r not using the motor for racing or even street drag racing then it would be a waste. Your $635 long block will most likely withstand anything you could give it short of racing.
    David
    <a target="_blank" href=http://www.extremeblazer.com>ExtremeBlazer</a>
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I think adding flat top pistons for a little more compression would be a good idea, but cheapy cast ones will work just fine.
    Tim
  5. Rix_Gotta_Blazer
    Rix_Gotta_Blazer 1/2 ton status
    Dec 13, 2001
    104
    Hollister, CA
    if you dont mind me asking, where did you find a $635 long block? i have checked all over and i have only found long block for $700 and up. thanx.
    i liked this bumper sticker i saw, "real Americans DRIVE American"
  6. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    City Motor Supply in Dallas and San Antonio. $635 is a complete motor from the basics to the rockers and a gasket set. Even comes with some Blue Silicon and engine paint. Website is www.citymotorsupply.com I forgot to mention, the pistons that are stock are dished cast pistons, the ones I want to put it are Flat Top 4-valve relief Hypereutectic with anti-friction coating from Federal Mogul.
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Most places like that have different options for their motors. You also might want to see if you could just have them install the flat top pistons to start with insted of breaking the engine apart after they just put it together.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
