To replace bearings or not, that is the question
Discussion in 'The Garage' started by sandawgk5, Aug 5, 2005.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    One of the last things I have to do to my 14FF is to set up the gears. I have purchased an open carrier and it came with bearings. My question is should I just get the master install kit and replace all the bearings including the 3 on the pinion or just inspect them and reuse them. And also where is a good place to get a master install kit I have found them for about $120 with everything including ring gear bolts is that about normal?
    Ira
  2. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    If you're going to do all the work of setting up a new gear set, might as well 'insure' it with new bearings. Make the old ones into setup bearings. $120 s about right for a master install kit.
  3. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    I would definately go with new bearings!!
  4. sandawgk5
    Oct 28, 2003
    6,881
    Thanks that is what I thought but I just wanted to make sure I was not going overboard.
    Ira
  5. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Answer a question with a question, Do you want to go thru this again in the near future?
    I've been able to buy name brand bearings from the local bearing house for about what some of those bearing kits cost, and who knows what brand comes in them.
  6. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    buy the master install kit.
    FYI, ive bought master install kits from 4WHP and Randys and both were had Timken bearings.
