To swap or not?
Discussion in 'The Garage' started by garlicbreath, Apr 26, 2005.
  1. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    Quick and short, 1971 blazer, 350, Th350, NP205, D60, 14B, 4.56's and 37's and 2 brand new CV shafts. I need a lower crawl ratio, so I was thinking 2 options, 203-205 doubler or swap in a 700r4-208. The latter being much cheaper. Pro's-con's?
  2. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    i wouldn't go to a 208 unless it has a fixed yoke. Why not a 231/241?
    j
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    Ya, if you're going to go the route of a 208, I'd find a 241 and put a SYE on it. Or go with the doubler.
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    Ok here is how i see it. You have a 350 now, not a super strong tranny, but its ok, for the ultimate beef, youd want th400+dubbler.
    you already have a 205, but it might be the wrong input, give a call to northwestfab, or send them a pm thay can help you ut alot with this decision.
    700r4 is the same or a little less stronger than your current tranny, depending who you talk to. they can be built to handle qutie a bit of abuse, dr. watson from ord has used one for along time., i dont know much about the 208 though, sorry other than alum case and chain drivin, both are weak.
  5. garlicbreath
    May 17, 2003
    1,136
    Denver
    Reason I was thinking 208 is they are easy to find already hanging off the back of a 700r4. And 700r4 has lower first gear plus overdrive. But I agree about the slip yoke, I have never liked them. Does anyone make an SYE kit for a 208? To go with a doubler, I would have buy and have installed a new output shaft in my th350, plus the cost of the doubler kit, and a 203 rangebox.
  6. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    depending on your rear driveshaft angle, keep the slip yoke. with 37's you only need a few inches of lift. so the dangle angle shouldnt be too bad for the SY
  7. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    didn't they use 231s or 241s in later K5s? behind 700R4s?
    j
  8. sweetk30
    Nov 1, 2004
    25,549
    543
    horseheads , ny 14845
  9. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    I run a 700r4 208 slip yoke cv combo with 14 bolt dana 60 and 35 inch tires, so far no problems and you would save yourself some cash. Its great for me but mine is also a daily driver and I love the over drive but if I had the money it would be 400 doubler combo.
