to swap to 84-87 column, would you have to swap wirin harness also
Discussion in 'The Garage' started by R72K5, Nov 24, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    the entire cab dash harness ? in order to swap older truck over to column mounted wipers and brights ?
    probably so, but i want to make sure, plus has anyone here done this ? im thikin about snaggin column and cab harness from the 84 k10 we are going to use for parts out here, and swap my 83 over to that /forums/images/graemlins/laugh.gif /forums/images/graemlins/thumb.gif
    could i swap turn signal stalk and harness parts from the 84 automatic trans column over to my 4 speed 83 column and still be able to use the column ignition lock housing ?
    are wiper motors still same 83 to 84 ?
    thanks
  2. dyeager535
    26,975
    Can only help a bit.
    More than likely, the cab harness would have to be changed over, unless you wanted to do some cutting and splicing. Wiring colors, position, and quantity all CAN change based on the year of the truck, and the options it had. (things like door/headlight buzzer, etc)
    The column parts are all essentially the same, although when I went from auto column parts to 4 speed/floor shift column parts, I had to "clearance" the cutout for the turn signal/headlight switch. Kind of weird, that may have been a year thing (although both were 80's), or bad tolerances on the two parts I was using.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    cool thanks, that helps /forums/images/graemlins/laugh.gif
    i assume that harness swap is required, so ill just leave it at that, except that the 84 harness is auto trans 4x4 one and the 83 truck is
    manual trans 4x4, so hmm..
    thanks
