toasted calipers bushing, what could've caused it?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Nov 24, 2002.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    toasted calipers bushing, what could\'ve caused it?
    I was wrenching on my truck tonight and noticed that the lower capliper bushing on the drivers side was shot and the bolt was backed out about a 1/3" could the caliper bolt backing out have caused the bushing to self-destruct?
    Chris
  2. Grim-Reaper
    7,385
    Atlanta
    Re: toasted calipers bushing, what could\'ve caused it?
    Caliper as in brake caliper? Mud kills them suckers fast. I have to replace them a couple times a year. First time I went looking for them the Pep Girls told me the only way to get them was with new calipers. /forums/images/graemlins/rolleyes.gif
    You have to aske for a Brake Hardware kit. It comes with the bushings and the metal retainer clip for the piston side pad. Like $4. They also have a special grease to put on those bushings that helps them last longer.
  3. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Does that kit come with the O rings for the bushings that go into the caliper housing? Those are what I am looking for. Mine are worn out and I need new ones
  4. Grim-Reaper
    7,385
    Atlanta
    Yep all the o-rings I think it has everything but the pins. you have to get those seperate.
  5. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Thanks Grim...I think what happened is that the brake caliper bolt backed out a bit and when I hit the brakes hard the bushing self-destructed...I bought the caliper hardware kit from Napa for like 4 bucks...it takes care of one caliper for me...thak man...
    Chris
  6. slider
    May 7, 2001
    547
    Thanks Grim Reaper
