Toe in for my truck.
Discussion in 'The Garage' started by Big'nBadK5, Aug 21, 2003.
  1. Big'nBadK5
    Big'nBadK5 Registered Member
    Feb 9, 2003
    84
    Pjs, Ny
    I have to try and manually set my toe in on the truck cause no shop around here will touch it for some reason. any idea what it should be?
  2. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Probably no more than 1 or 2 degrees but I really am just guessing there. /forums/images/graemlins/1zhelp.gif
  3. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    between 1/8" and 1/4" toe in. closer to 1/8" with the 35"s
  4. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    closer to 1/8"
    Yep. Just had mine aligned to that.
    My Camber was reset to 1/2 (it was 1-3/4) which I think is max, more like an 1/8-1/4 is preferred. The factory camber spec for the later models is 1.5 +/-.75 That means they can set to +2-1/4 and be within spec /forums/images/graemlins/eek.gif
    Thats why my tires were wearing on the outer edges /forums/images/graemlins/tongue.gif
  5. troyboy
    troyboy Registered Member
    Mar 13, 2003
    13
    we set them at 0 degrees at our shop
  6. LlanoK5
    LlanoK5 1/2 ton status
    May 26, 2002
    202
    Llano, Tx
    where and how does the camber adjust?
