Toe in?!
Discussion in 'The Garage' started by Wally81k5, Aug 27, 2003.
  1. Wally81k5
    Wally81k5 1/2 ton status
    Jul 14, 2002
    139
    Cold Lake Alberta
    I was told that an 87 gmc jimmy, for a front end alingment after changing tierods, can only be done with the toe in measurment, I want to do it myself, I heard it's 1/8 inch toe in. Is this right? any advice? Mine has the 3 peice tie rod.
    Thanks thumper for the info! save a me more money!
  2. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Changing tierods will only affect tow-in. 1/8" is a good number.
  3. Wally81k5
    Jul 14, 2002
    139
    Cold Lake Alberta
    OKay good, now all i need to know is where is the toe in measured from? How do i measure it??
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Measure the front of the tires say the inside edge of the tread from one side to the other. Then do the same thing in the back. The front should be 1/8" less than the back.
  5. limey
    limey 1/2 ton status
    Dec 17, 2002
    121
    midland texal
    i have a friend that works in an alignment shop and he said they take sharp tool place it under the tire and spin. tire so thier is a small line all arount the tire and take the readings off the line you scribed in the tire. that way you know the line is the same distance in the front and the back of the tire
