Toilet Paper tube drug paraphernalia
Discussion in 'The Lounge' started by newyorkin, Jan 30, 2007.
  1. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    What's the deal with this? I remember something about addicts using toilet paper tubes for something, coke, heroin, I can't remember.
    I'm finding a bunch of these things outside one of my job sites that's fairly secluded. I know there are vandals and punks hanging around there, but I'm curious what their level of decay is...
    So what do drug addicts do with the tubes? And what drug is it?
    I know one of you crackheads must know...
    :haha: :haha:
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    You use them for marijauna. I think they call it a steamroller.
  3. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,956
    249
    Released from Pueblo, told I belong in Southpark
    Yep they might have a whole ripped or cut into the round side somewhere near one ind and they use tin foil or a peice of screen to form the (bowl). Cover one end with hand other end on mouth and light the bowl and when the tube gets filled with smoke release the hand from opposite end and poof smoke goes in. Yep called a steam roller. They also use aluminum cans and dent and poke a few holes.
  4. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I see... I found a few with burn marks on the side, but I didn't notice if there were holes in them.
    Marijuana's not so bad. Still illegal and stupid, but I'm not going to bring defensive weapons with me to the site if that's all it means.
  5. Larry_in_Tx
    Larry_in_Tx 1/2 ton status
    Oct 24, 2002
    404
    Houston Tx.
    They must be hard up using those because you waist a most of the bowl…or so I hear.:crazy:
  6. gjk5
    gjk5 3/4 ton status
    Mar 17, 2004
    5,312
    Grand Junction, CO
    Be careful Ratch, the tubes are also used by coke and heroin users, they make a paste, rub it on tinfoil and burn it from underneath using the tube to inhale it. From the way you described them this seems more like the probable use.
  7. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    You can use a steamroller to smoke crack, meth, etc. Look for empty brillo boxes or remnats of steel wool. You use the steamroller as described above but you load the bowl with steel wool to filter the rock. Not the most effective method but it works.
