Tomarro I am Removing All My Emmissions
Discussion in 'The Garage' started by Looksback, Jun 7, 2003.
  1. Looksback
    Looksback 1/2 ton status
    Aug 12, 2002
    120
    Montana
    Like the post says I am going to remove all the emmission devices, except the EGR, but everything else such as smog pump, all the mounting brakets, charcoal canister, stock air cleaner, all hoses, and almost everything involving emmissions and there mounting hardware. But the reason I am posting this, and I know I should not be posting this here with out haveing paying my membership, but all of these devices I am giveing away to who ever wants them they just pay postage, becuase I figure its sort of a waste throwing all of this away when there is some body that can use it.
    its being removed from a '86 K5 Blazer, with a 305cid and all of it is in working order
    LooksBack
  2. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    sweet! i did too (well, just the mufflers) and i don't have EGR or smog or anything else (nope, no cats) and you will be happy with the throttle response, i certainly was, MAN that thing revvs quick now. good luck, don't get caught.
  3. Looksback
    Aug 12, 2002
    120
    Montana
    Well, here where I live there is no emmission testing, or inspections, so none of these devices will be nessery. after I do this than I plan on adding on dual exhaust, with glass packs. But I figure there is no need to just through this stuff away. What I am intrested in is how did you remove you EGR? did you have to change your intake manifold?
    LooksBack
  4. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I think you can get a cover plate to go over the EGR hole, however, not too sure on that one. I bought a edelbrock performer manifold, I would reccomend that. Its of nice construction and aluminum always looks cool.
  5. Looksback
    Aug 12, 2002
    120
    Montana
    Yeah, I had never thought of that, would you know where I might be able to find one of these cover plates?
    LooksBack
  6. dyeager535
    26,979
    I'm gonna guess that in about 3-5 years, (if you don't actually ask what you are accomplishing) you will figure out that what you have done is basically worthless from a power producing standpoint. And for that matter, will help reduce your MPG's.
    FWIW.
  7. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    I would keep that stuuf stored in a box. Someday you might need it. I did that to all my cars in Oregon and when I moved down to AZ I needed them. If I were you I would keep it before giving it away or throwing it away.
    You can just make the plate. If you don't want to then I would go to a wrecking yard and start looking. Most cars in the Oregon junk yards had the emmissions removed and all the small blocks had the plate on them. I suspect you will find the same is true for Montana. Of course, that is if the local parts store does not sell them for a couple bucks.
  8. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Don't remove the air pump, just cut the belt. Much easier so that way if they start doing sniff tests, you can pass by putting a belt on.
  9. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    If you just take the belt off, it'll take some time to get it working again since it'll probably seize up on ya. That's what happened to me, but I just took it apart and did a little R&R...
