Too Many problems
Discussion in 'The Garage' started by bcshaner, Aug 16, 2005.
  1. bcshaner
    bcshaner Registered Member
    Aug 10, 2005
    9
    BC Canada
    Well the story so far....
    My 89 full size blazer with 6.2 diesel blew the stock 10b rear end .... for the second time!
    This time i decided to change something so it wont happen again. I bought a 12b rear end complete from a junk yard and it turned out to have a gov locker which i did not want so i took it back and asked for an open 308 12b.
    I got it yesterday and got it home, put all new seals in it and installed it and went to finish up by installing the drive shaft and it wont attach!!
    My 89 blazer universal is bigger than the universal that was on the vehicle this rearend came off of. Is there a type of universal that will fit my driveshaft and the new smaller rearend attachment point? It seems like i need a universal with a snapring attachment on two of the ends and the free caps on the other two ends, know what i mean? Anyone ever come up against this problem. Do I have to uninstall this rearend, new seals and all, and get one with the right driveshaft attachment fit? This would be the third rearend i have tried to install to replace my stock 10b.
    Getting Frustrated in BC, BCshaner. :doah:
  2. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    You should be able to by a conversion ujoint. In the us they run about $30.
  3. bcshaner
    Aug 10, 2005
    9
    BC Canada
    2 styles
    Are there just basically the 2 different styles? :crazy:
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I don't know what you have for auto parts stores up there, but down here I can go to Napa and tell them the two vehicles that I need the joint to match and they can look in their book for what I need. For example - You can ask for a u-joint for a 1989 K5 with a rearend from a 1976 K10. They should be able to look up what conversion joint you need. I know the joint exists because I have bought one before, but it's been too long ago for me to remember the part number.
  5. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    yep what they said :waytogo:
  6. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    What exactly were you breaking in the 10 bolts? 12 bolts are marginally stronger, if at all.
    10 bolt =
    8.5" ring gear
    28 or 30 spline 1.31" axles
    1.626" diameter pinion
    12 bolt =
    8.875" ring gear
    1.438" diameter pinion
  7. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    To convert your Saginaw 44 (S44) joint to a 1310 style joint you need,
    neapco pn: 3-3130
    John
