Too much brake pedal travel...
Discussion in 'The Garage' started by 1985K20, Apr 28, 2005.
  1. 1985K20
    1985K20 1/2 ton status
    Jan 11, 2005
    191
    Quebec,Canada
    I put new brake hardware all around on my truck lately except for drums(they were fine).
    Im pretty sure I had rear brakes adjusted right the first time but I was still getting too much pedal travel.
    So after double checking I replaced leaking rear left wheel cylinder, then bled the brakes all around.
    Pedal was still goin way to far so i bled to the master cylinder: no change at all :mad:
    Well i said wtf is it then?? It ended up being the rear brakes had to be readjusted!!! (I did that the first time :dunno: )
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    low brake pedal is one of 2 things if you've only had the rear brakes apart. misadjusted shoes, or air in the lines
