Too much fluid in the trans case
Discussion in 'The Garage' started by RAY, Dec 29, 2004.
  1. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    My front input seal went bad and tranny fluid leaked into the transfer case. Now It is making a groaning noise like gears meshing together. I was wondering if running with too much fluid could damage or cause something to shift in the t-case to cause this new noise. I am thinking about rebuilding it, but would like to have an idea if a rebuild would solve my problem or just waste my time. I have already replace the seal, but still have the noise. Any help would be greatly appreciated.
    Thanks,
    Ray
  2. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Did you drain the t-case and replace it with new fluid or is the contaminated oil still in it?
    Kind of confusing? What trans and t-case are you running?
  3. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Assuming you have a NP205 T-case and the ATF thinned out your gear oil. If so replace the o-ring and refill with gear lube....
  4. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    sorry to highjack but what type of lube do you put in a np 208
  5. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    ATF won't hurt a 205, they ran them in the later 80's.
    My experience in rebuilding them is that with ATF there seems to be a bit of wear on the teeth, whereas with gear oil no marks occur.
    Just drain it and fill it again with 90wt.
  6. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    NP208 fluid
    The NP208 is suppossed to use dextron ATF--but many I've serviced had 80-90w gear oil in them,not the correct fluid,but it didnt seem to do any harm --but then,I didnt have the cases apart,I just changed fluids(and I put ATF back in!).:crazy:
  7. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    Prove it.
    ATF will harden the seals in the case and create leaks, also as you addressed cause premature wear.....
  8. RAY
    Jul 4, 2000
    281
    Austin, Texas
    Sorry of the confusion, I am running a 700R4 and a 208. I know it is a chain drive, the noise it is making sounds like gear meshing together. I am hoping someone else might have had this problem.
