Too Much of a Good Thing...Flex
Discussion in 'The Garage' started by B_to_C, Oct 10, 2003.
  1. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    Does anyone else have this problem? /forums/images/graemlins/confused.gif when i'm going over an obstacle that flex's my front suspension the stock front bumper gets all diagonal to the body. i know frames flex but this is so bad that the corners of my front bumper have taken out my front blinkers almost every time i've been off-roading and have even done some sheet metal damage just around the blinkers because the bumper has flexed so differently from the body. the only reason i could think of was maybe my front body mounts ripped (or rotted) off the frame at some point. help? /forums/images/graemlins/ears.gif
  2. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    I don't have that much. I'd look into see if your core support is even attached to the frame. A lot of times the little supports on the frame rot out. In combination with that the cups and underside rubbers rot out and quite often you can move the core support around a lot.
    I have relatively new body bushings and cups. They were all replaced last year with new OE ones.
    I have a swaybar so I don't get the flex you do but here is a picture of the box flexing as compared to the cab:
    http://www.wrath.com/projects/vehicles/images/84k10/wheeling/blackcreek_flexing-101003/flexinglog3_09.jpg
    As you can see I don't have the flex in the front like you're talking about. A lot of it probably has to do with the sway bar.
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    check out the body mounts, if they are rotted and allowing the body to flex off the frame...it could cause your problem..
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Flex doesn't cause that, bad body mounts do. Ceck 'em out, I'm sure they're rotten.
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Mine does the samething, my fan hits when I get flexy. I'm installing new Polyurethane body mounts to help correct the problem.
  6. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Yes, I have damaged several rad supports and busted alot of front mounts and bushings. I saw this on another K5 and did a similar thing. My radiator support has 1 spring loaded mount in the center and the front bumper is still attaced to frame, but extended out an inch to clear sheet metal [​IMG] [​IMG]
    This allowed the radiator support and the body to stay fixed and allow the frame to flex with no body damage.
