Too much pressure?
Discussion in 'The Garage' started by Tweetysuarus, Oct 27, 2002.
  1. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Has anybody had their mastercylinder build up too much pressure and seep out fluid past the steel cap & rubber gasket? if so how did you cure it? I have already replaced the gasket and adjusted the spring clip for more tension on the cap, I am about to replace the the steel cap and the spring clip.
    Thanx,
    Bill
  2. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Anybody had this problem before? Somebody has to of run into this pressure problem? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
    Bill
  3. trouble1
    trouble1 1/2 ton status
    Sep 28, 2002
    346
    travelling, probably lost
    Sorry....youve always been great about helping me, but I dont have a freaking clue. If ya figure it out, let us know what ya did... /forums/images/graemlins/confused.gif /forums/images/graemlins/k5.gif
  4. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    seeing you have a 76, i am guessing you have a the older steel resivoir. check to see how rusted the seal area is, it could be so rough the rubber gasket cannot seal. also try to lower the level in your resivoir and see if that solves the problem.
    later
  5. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Thanx, I'll check it out!
    Bill
