too much road noise to hear the stereo
Discussion in 'Audio' started by ugly, Oct 26, 2004.
  1. ugly
    ugly 1/2 ton status
    Aug 8, 2004
    157
    Denver
    the 454, flowmasters, and military tires are killing my sound..
    72 blazer with a full rubber mat on the floor, 40 watt stereo, and kickers mounted in the fenders (pointing at eachother) behind the front seats.
    should I add door speakers (already cut) or build boxes on the roll cage above my head, or mount speaker into the head rest or add an amp?
  2. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I would definantly try and get that cab sealed much better first. Adding speakers and power will just make your ears ring after you get out from trying to outblast the road noise with the stereo.
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Some quality speakers in the headrest might be a good idea.
  4. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Reducing the "noise floor" will be the better way to deal with the issue. Making the stereo LOUDER will be annoying, and you'll still lose the subtleties of the music using that solution.
    There have been plenty of posts about McMaster-Carr Polymeric mastic as a cheap alternative to Dynamat. It sounds like you need LOTS of it.... at least it's cheap enough that you can afford to go wild with it.
    I'd hit the floors with at LEAST 2 layers (3 would be better) and then attack the inner bedsides and the inner door skins. The more you can deaden that metal, the better the existing stereo will sound.
    Also, I know it sounds obvious but if your exhaust has "turndowns" under the truck, you are creating a real noise nightmare. Get the exhaust rounted somewhere out the back or rear corners. Also, try grooving or at least "siping" your tires. Breaking up those large treadblocks can really help to calm the noise down. I know this from personal experience on my TSLs.
    /forums/images/graemlins/usaflag.gif
  5. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Hey Greg, do you remember about how much you paid for enough Polymeric mastic do do you Blazer?
  6. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    32" x 54" is less than $15.
    McMaster p/n = 9709T19
    /forums/images/graemlins/waytogo.gif
  7. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    yeah, I have the webpage on their site open to it but how many sheets did it take for say 1 layer?
    Sorry for confusion
  8. ugly
    ugly 1/2 ton status
    Aug 8, 2004
    157
    Denver
    sounds like dampening is the way to go. how does the stuff that you reccomended compare to rhino lining, or paint on versions of sound dampening?
    if I use those sheets, can I add a product like rhino in the future?
  9. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Or you can try Quiet Coat. Read about it here .
