too much torque
Discussion in 'The Garage' started by shupach, Jun 6, 2003.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    so i today i was like, im gonna drive the truck around the block since i just got the engine running etc, well it wouldnt go in gear so i was like wth. kill it and look underneath...no more torque converter bolts, found em later sheered in half, so wat are my options now? would this be an excuse for a better tc and flexplate(seems to be gone too).
    thanks,
    phill
  2. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    When did the bolts break off exactly? As in, when you started it, when you put it into gear...
  3. shupach
    Dec 28, 2000
    648
    Dallas, TX
    im thinking in gear, im gonna order a new TC and flexplate from summit, needed it anyway.
    phill
  4. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    This happened to my friends Firebird...no one knows how this happened...
  5. MousePowrd
    MousePowrd 1/2 ton status
    May 7, 2003
    215
    Saginaw, MI
    Most likely a couple came loose. Did you find some that were not sheared, just laying loose?
  6. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    were they actual TC bolts or just grade 8 stubbies. Real TC bolts are made to withstand the shearing force a TC and flexplate provide. Go spend $3 and get actual TC bolts.
  7. shupach
    Dec 28, 2000
    648
    Dallas, TX
    they were the bolts used in the torque convertor when i pulled the engine, ill post some pics later tonite, two of them were cut in half however the first one kinda just fell out.
    phill
