Too much $ ?
Discussion in 'The Garage' started by bear76, Jan 15, 2007.
  1. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    I have a line on a sw 14bff and matching dana60 with 4.11's. Guy said he'll take $900. If they need SOME recondidtioning, will they still be worth it?
    Thanks.
  2. merace19
    merace19 1/2 ton status
    Sep 19, 2003
    372
    Mobile, Alabama
    If you need them then yes. It also depends on what needs to be done to them.
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    how much reconditioning? like brakes? if so, then its a fair price
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Unless the carriers have been open to rain, it is a good price.
  5. bear76
    Oct 16, 2005
    1,065
    here
    I'm going to see them today or tomorrow. I am assuming they need brake jobs and general cleaning up. I don't belive they need a complete rebuild. We shall see.
  6. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    If that is the case, its a good deal.
  7. bear76
    Oct 16, 2005
    1,065
    here
  8. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    Look a little rough... I'd pull the covers.
  9. K5Greek
    K5Greek 1/2 ton status
    Nov 25, 2005
    2,054
    Vineland, NJ
    pop diff covers and check drums
  10. bear76
    Oct 16, 2005
    1,065
    here
    When I pop the diffs, what exactly should I look for? Same with the drums.
    Thanks.
  11. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,991
    130
    Make sure water has not been sitting inside the diff and that the teeth on the gears look okay. As for the drums, just check to see what shape the drums are in and what the shoes look like. Also make sure that the wheel cylinders are not leaking. I would jump all over those for $900.
  12. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    What he said, when I got my D60 I didn't even check inside the diff, because the BOM decoded that it had 4.10's. At home I got a nasty surprise. The diff was full of muddy water, NOT gear lube. The gears and bearings are shot. For my LOW initial purchase price, though, I figured I can deal with it.
  13. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    If I were you I'd evaluate based on what a COMPLETE rebuild would cost....
    Add up all the parts and then decide if it's still worth it to you. I paid $900 for the same setup you're describing and thought that was a pretty fair price.
    ....it's foolish to buy a set of 1-Tons and automatically assume that they will work fine because they "look" good. (Ask MuddinManny if you don't believe me!) take the extra time to tear it down, inspect everything and rebuild it RIGHT before you install it. :usaflag:
  14. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I paid that much for my combo and the 60 was in pieces. I put it back together with the existing parts except the outers got new bearings and ujoints and the 14FF got a new carrier, locker, and gears to match the front. All in all I got about 1800 in my front and rear. I also do not have discs on the rear.
    Ira
  15. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i ended up completely rebuilding my 14b, and just replaced ujoints, lock outs, gears locker and install kit in the d60, everything else looked good
  16. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,030
    1,347
    Kzoo, Mi
    :eek1: :eek1: :eek1: :eek1: :eek1:
    Ditto.
