took the plunge, gone Veggie!
Discussion in '1982-Present GM Diesel' started by Pookster, Jun 4, 2004.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Saw my friend do it, so I did it. Dumped 15 gallons of veggie oil into my tank straight. had about 15 left in my tank. So far, its runnin, and running ok!
    We'll see how the cold start is tomorow morning....
  2. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Sorry, forgot to say, its waste vegetable oil from deep frying!!!!
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Big difference, the WVO gets thinner, it will still thicken when cold, but it's more combustible after being cooked.
    Let us know what happens, and by the way filter them real well, you don't want your filters to plug up very fast and you don't want your injectors to plug up either.
  4. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Yeah, I filtered it pretty good, the filter media was at least smaller than 10 micron. (two layer fiberglass cone filter). The oil that came out from the other side was very very clean, no visible bits, no bits I can feel.
    Engine's running good so far. 100 miles down.
  5. 6.2gmc
    6.2gmc Registered Member
    May 27, 2004
    8
    Derbyshire,England
    Hi i was just wondering did you just mix the filtered veg oil with the diesel in your tank with no engine mods?.If you did is there a mix ratio or would it run on veg oil alone after its running. /forums/images/graemlins/k5.gif
  6. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    As long as you have a good percentage of diesel fuel in it and you are using cooked oil you should be OK without mods.
    If you use staright vegy oil you will need topreheat it to liquify enough to work, that is all.
    I am working on something like that for my engine.
  7. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I did about a 60% diesel, 40% WVO. Yes, totally right about the viscosity issue-
    You can use 80WVO/20 Kero if you wish as well, from what I have heard. Basically since diesel is nothing more than oil with kero, your just making the same blend.
    No engine mods whatsoever. I did filter it very well, and used only high quality fried oil. The color was consistant with pictures of bio diesel I've seen, so I wasnt too worried.
    however, if you get oil that is about the color of used motor oil, I'd be a little wary of just putting it into the tank. Basically, the viscosity is the key. So if you either A. heat it up, or B. thin it out, you'll be good to go.
    But before you take the plunge, let me put on a couple hundred more miles. The engine isnt complaining, it acutally is quieter idling and on cold start. Power is a little bit lower, about 10HP it seems.
  8. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I just added some more, this time from a different place-it looked totally nasty, like dark colored and all
    surprisingly, it filtered through without much particles. I think its just a little burnt. Runs ok, this batch was definately french fries! /forums/images/graemlins/histerical.gif
  9. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
    Well if it's burnt it actually is less viscous, and more volatile or combustible.
    /forums/images/graemlins/thumb.gif
  10. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    I mentioned this to a friend of mine and he said, "You might want to warn that he'll have to watch his fuel filters
    for a while as the high glycerin content will start cleaning any and all
    gunk out of his fuel system." FYI Hope its working OK.
  11. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Glycerin? Clean? eh? I think he's thinking bio diesel. im doing WVO (waste vegetable oil). i've never seen corn oil clean anything..... /forums/images/graemlins/rotfl.gif
  12. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    The glycerin is what makes it thick, it's like Gelatine, it thickens when cold, about cleaning though I have no idea.
    /forums/images/graemlins/dunno.gif
  13. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    understood the glycerin part, but I didnt understand the cleaning part. I know to watch the fuel filter, as the glycern (and any fatty chunks of chicken wings) will clog the filter after a while. But the main thing was the cleaning- veggie aint gonna clean nuttin, unless its bio diesel form.
  14. ramack
    ramack Registered Member Premium Member
    Jun 20, 2004
    72
    5
    Centennial, CO
    So why go veggie? Because it's something new or it's cheaper?
  15. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Cheaper and cleaner.
    /forums/images/graemlins/woot.gif
  16. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Cheaper (Free) Cleaner- (better cleaner emissions)
    More Politically correct (no more paying for rediculous gas prices)
    More Eco Friendly (recycling).
    Quieter- Wow, its amazing how quiet the pump is now.
  17. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    So are you using a 60/40 mix now or what?
    Tell us more about the results so far.
  18. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I would! except im not at home! I'll be home in a few days, when I will get the rest of the parts needed for the part time veggie conversion.
  19. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Where are you getting your oil at? Just going around to mickey D's and asking for used oil? /forums/images/graemlins/histerical.gif
    Seriously though, where at? /forums/images/graemlins/ears.gif
  20. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    MAN, I should try this with my diesel...since I work at a grocery store I can get tons of used oil from the service deli!! they through out about 5-9 3 or 4 gallon jugs a day...I think. /forums/images/graemlins/peace.gif
