Top Bolts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by J.Lance, May 29, 2003.
  1. J.Lance
    J.Lance 1/2 ton status
    Oct 8, 2002
    145
    Arvada, CO
    Can anybody tell me where to get the tamper proof torx socket to remove the top bolts? Looking for an easy answer before I drill the torx bit I have now. Thanks.
    Jason
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    i believe that NAPA, and carquest carry them, if not, then check out some hardware stores. i think home depot even has them.
  3. 45acpJr
    45acpJr 1/2 ton status Premium Member
    Jan 7, 2003
    632
    Tucson, Az
    Any hardware store, parts house, even Sears carries them /forums/images/graemlins/thumb.gif
  4. J.Lance
    Oct 8, 2002
    145
    Arvada, CO
    Are you guys talking about the Torx bolts with the tampler proof design. It looks like a regular torx but then has a raised circle in the middle so the correct socker would need the middle hollowed out. I don't recall seeing these at the normal tool stores. I have a complete set of torx sockets, just not the one I described. These are on my '90 Jimmy. I believe they only showed up in later years.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Jason
    Autozone has them.
  6. BigBadJap
    BigBadJap Registered Member
    May 23, 2003
    76
    Alberta, Canada
    I found my set at a store called Princess Auto, which I don't think you have in the states, but it looks like House of Tools, carries them...
    http://www.houseoftools.com/product.htm?pid=83862
    (Just double check to make sure they have the right size bit listed in the set) Shop around if you can, they seem to be on the expensive side.
  7. J.Lance
    Oct 8, 2002
    145
    Arvada, CO
    Thems the ones I'm looking for!! Thank you very much. Also, I'll check A-Zone again but I was just there over the weekend and they had the regular Torx set but not the tamper proof set. Thanks again! /forums/images/graemlins/thumb.gif
