Top mount tie rod conversion
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Predator, Aug 27, 2002.
  1. Predator
    Predator 1/2 ton status
    Jun 19, 2001
    130
    OKC,OK
    Can you take a bottom mounted tie rod and move it to the top of the knuckles by retapering the holes or drilling new holes & tapering them? If retapering, would there be enough metal left to do any good? Can't look at the truck right now, but just tossing the idea around and was wondering if anyone has done it.
  2. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Sure, if you want to go through the hassle. A better plan is to just get a set of older Dana 44 knuckles with the "tie rod from the top".....especially the set with the flat-top on the passenger side (pre '76)- for the crossover steering mod. I may have a set of "tie rod from the top" (non flat-top) knuckles. These would be useful if you do not plan on crossover. Send a PM if you are interested.
