top post conversion
Discussion in '1982-Present GM Diesel' started by LA90k5, Jan 22, 2007.
  1. LA90k5
    LA90k5 Registered Member
    Jan 8, 2006
    40
    Lake Charles, Louisiana
    Has anyone on here converted their side post battery cables to top posts? I need some ideas for the passenger side battery where the positive cables are connected. The only thing I have found so far that I could do is cut the ends off and crimp a lug on the cables and put a marine style terminal on the battery post. Anybody got a better idea?
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    On the old farm tractors I grew up with the terminal was just bolted on behind the nut already on the terminal clamp. You could even put a longer bolt in and double nut it.
  3. 4x4_76
    4x4_76 1/2 ton status
    Jul 22, 2001
    628
    Ylämaa, Finland
    That's pretty much the way I had cables on Blazer. They looked a bit hack because shop where I bought lugs and terminals didn't have proper pliers to press lugs on cables. And lugs where little bit big for the cable I used. But they worked. No more problems with voltage loss :D
  4. kennyw
    Jun 9, 2002
    13,224
    94
    Though I did use the marine style terminal on my '79 K20 with a single battery and never had a problem starting the truck all the way down to 0 deg. The battery cables were 2 ga as well.
  5. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Check your military surplus guys. The military is using a very heavy duty terminal with a bolt through it for cable connections. They are a whole lot heavier duty than your average marine terminal.
    Jimbo
  6. smalltruckbigcid
    smalltruckbigcid 1/2 ton status
    Dec 25, 2004
    3,866
    3
    NE Wyoming
    Semi's use a top stud thats 3/8ths course thread. And allmost all the truck dealers and bigger truck parts houses have the parts to make killer cables. Then its off to Sams club for a group 31 top stud battery (925cca and 69.95). The blazer and the semi have the same batteries now:wink1:
    George
  7. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I made my own 2/0 guage welding cables with a lug, soldered not pressed on and marine battery posts.
    Works great :D
