top removal wrench
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dammit32, Sep 20, 2002.
  1. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    where would I find one?
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Mine has 1/2" bolt heads. If you have Torx or something go to Autozone or Pepboys or Sears.
  3. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    it is a t-40-S. if you can not find one i could send you one.
  4. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    i got a set of 6 or 7 different sized bits from Car Quest for 20 bucks. i never knew how handy that set is. well worth the money. it came with a rubber holder for the bits and an adaptor for a 1/4" drive.
  5. pfloydmaster
    pfloydmaster 1/2 ton status
    Mar 30, 2002
    156
    Grottoes, Virginia
    I found a set at Pep Girls for around $10.oo with the adapter and ruuber case. They are security Torx bits (have a hole in the center of the bit). Hope this helps! /forums/images/icons/grin.gif
  6. dammit32
    Jul 20, 2002
    365
    Maine
    mines a torx with a pin in the middle
  7. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    go to sears.... may cost a lil more, but the quality and lifetime gurantee is never bad!
  8. pfloydmaster
    Mar 30, 2002
    156
    Grottoes, Virginia
    The security Torx bits have a hole in the center to fit bolts with the pin. I've got the same bolts and that's why I bought the set. A good investment unless you want to change the bolts. Good luck! /forums/images/icons/grin.gif
  9. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
  10. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    Take them out with lock pliers and replace them with 1/2" head hex bolts. I ordered some security torx bits and they didn't even fit. The tab on the bolts in the truck was too big for the bit. The hex bolts make it way easier.
