top removal
Discussion in 'The Garage' started by smp92xj, Jun 15, 2003.
  1. smp92xj
    smp92xj Registered Member
    Sep 23, 2001
    14
    I would like to remove my k5 top for the summer. Is the removal tool a dealer only item(torx w/ dimple in the middle)? Also is there anything I should know prior to and during the top removal?
    thanks
  2. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    5/16th is what i want to think....
    there are two bolts underneath the bedrail in the back...i just cut those off and just use the bedrail bolts and the cab bolts to hold mine...no problems at all
  3. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    a lot of parts stores carry the tool you need. just check with them to see if they can get it.
    top removal: unhook dome light wires, and don't forget the 2 hidden bolts at the rear behind the interior bed panels.
  4. Blazn88
    Blazn88 Registered Member
    Dec 11, 2002
    83
    Northern California
    You also want to rub some Vasaline on your rubbers on the truck and the topper, so they don't get brittle and crack.
  5. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    It's called a Tamper proof Torx. Most auto part stores carry them I bought the whole set for about $15 in case I ever run into any other sizes.
    To make thinks a little quicker I put the bit in a cordless drill. I can take out all the bolts in about 5 min just make sure if you do this you use something with a little more torque to tighten them up when you reistall your top.
    -Brian
