top rust on rotors
Discussion in 'The Garage' started by scrappyk5, May 5, 2006.
  1. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    what is the best thing to use to get some pretty heavy top rust off my rotors.?
  2. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    if your talking about on the spot where the brakes will contact... you can either have them turned or buy new ones.. that is about it...
    remember these are brakes... YOU NEED THEM....
    if you use anything like sandpaper, grinder or anything... you will make an uneven clean surface and your brakes will not be right :crazy:
  3. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Yeah, X2 on that advice. Light surface rust is one thing, as your rotors are constantly rusting, your pads just knock it off. But heavy rust and pitting is bad. You can have the rotors turned for about $15 a piece, or just replace them. They arent too expensive. You can get cheap foreighn knockoffs from Advance, Autozone, etc... for really cheap. May not last as long, but they meet the safety requirments.
