top speed of your k5?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Erik Aalto, Feb 4, 2002.
  1. Erik Aalto
    Erik Aalto Registered Member
    Feb 1, 2002
    9
    I'm just curious as to how fast other blazers might go. my blazer is stock for the most part(1979 k5 2x4), and the speedometer ends at 100, but I have reached almost vertical with the needle, and I would guess I was going about 120-130 mph at the time. only specs I know of are 350 v8 with stock headers running through a cat to a flowmaster muffler and the piping is pretty thick if this would make any significant difference in speed?
  2. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    I had my 87's needle strait down. 85 is at about 4 o'clock so I'm guessing about 105ish. Stock 350TBI and stock everything. Mine's 4x4 but I had to slow down becuase I was in the wrong lane racing a friend and a curve was coming up.
    Ben 87 Jimmy
  3. blazin79
    blazin79 Registered Member
    May 26, 2000
    43
    Pocola, OK
    not sure how fast it is, but I can stand the needle straight up on my 74. probably around 120 or so. My engine is a little stronger than stock though. cam,intake,carb,head work.
    74 2wd Jimmy bagged on 18s
  4. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I know my Jimmy will cruise 90 mph down the freeway at only 2,800 rpms. Not sure of top speed though.
    86Jimmy 4"&35"s,87Burb 4"&33"s,69Firebird 525 hp,and 70GTO, 65 Howard V-drive PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My toys</a>
