top won't come off
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bad andy, Mar 12, 2003.
  1. bad andy
    bad andy 1/2 ton status
    Mar 5, 2003
    151
    Charlotte, N.C.
    top won\'t come off
    i tried to take the top off my 85 K5 today, took out every damn bolt i could find, and it wouldn't budge at all. /forums/images/graemlins/angryfire.gif am i doing something wrong?
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Re: top won\'t come off
    Did you remember the ones up top ???
  3. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    Its gotta go up before it can go back. Other than that /forums/images/graemlins/confused.gif. Try going in the back and lift it by standing up.
  4. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    STOOOOPPPPPPP! There are 2 bolts underneath the rail near the rear of the topper. Be sure you remove thsoe otherwise you can really mess things up. Also I soak the seals with 409 or windex to loosen them up. Good Luck
  5. dyeager535
    26,982
    191
    You forgot the two that are underneath the bed rail. Gotta pull the trim panels that go between the bed rail and floor on each side.
    One bolt on either side, farthest back towards the tail gate.
  6. bad andy
    Mar 5, 2003
    151
    Charlotte, N.C.
    ok, thanks for your help guys, i'll give it another try this weekend
  7. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    If you have trim panels and plan to remove the top often then take the two bolts from the underside out and toss 'em in the trash. /forums/images/graemlins/smile.gif
  8. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    just put a chain on it. and yank the chain with another rig.
    once that is done use the search feature to find out what you did wrong.
    you have two bolt going up into the top on the bed rails. as stated before you have to remove those first.
    grant
  9. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    I had 2 hidden bolts in each side on my rig. Have no idea what's up with that....But they're out now and not going back in!!!
  10. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    Not sure what year they started using Tamper Proof Torx bolts...that was another ugly surprise... /forums/images/graemlins/thumb.gif
