Topper Bolts, Lost a Nut!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rob 85K5, Oct 1, 2001.
  1. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    When I bought my 85 there was one topper bolt missing, the lower passenger bolt at the cab. After pulling the top, the retaining nut is not there either. I have a small rust problem above this where the body seem is. I believe the bolt not being there was a contributing factor in the rust.
    How can get a nut into the cap to recieve the topper bolt.
    I have taken all of the trim off and can't see a way in there, except for cutting sheetmetal.
    Any Ideas
    Rob 85K5
    <font color=orange>Bleedin' Chevy Orange</font color=orange>
  2. Rob 85K5
    1,487
    Pensacola, Florida
    c'mon
    Rob 85K5
  3. K5Junkie
    K5Junkie 1/2 ton status
    Mar 29, 2000
    499
    Gulfport, MS
    I am missing the same thing on the drivers side. I was putting my top back on one day when the clips that hold the nuts on the cab broke[​IMG] and i heard the nut fall somewhere inside metal of the cab. I see noway of fixing it without alot of pain[​IMG], so i haven't touched it. It has not given me any problems yet and it has been over two years that it broke[​IMG].
    Check out my pictures:
    http://www.geocities.com/jmargtx/index.html
  4. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I can't visualize this right now, but maybe get the correct size nut from a h/w store, put it on a long bolt, then finagle it into the hole and hold it there while you or someone else tack welds it to the body. Then unscrew the "handle" (long bolt), and bolt the top in with that.
    I have a serious rust issue in a similar spot, except right above the drivers side. I'd do what you can to seal up any holes, though, or water will run right down that column and rot it out at the bottom. Went to put my seatbelt on recently and found I pulled it out of the pillar, thanks to the water coming in from the top rotting a hole around my belt anchor!!
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    Welcome to America.
  5. Rob 85K5
    1,487
    Pensacola, Florida
    I have ground our all the rust to metal and will be welding up the holes soom. That has to tbe the worst spot to get to. I might drill some holes near the bottom for airation and to drain. It might even condensate inside that area??
    Rob 85K5
  6. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    How about a rivet-nut?
    Of the 5 toughest dogs in the neighborhood, my cat's ranked #3
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  7. Rob 85K5
    1,487
    Pensacola, Florida
    How about explaining that one a little more????
    Rob 85K5
  8. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    I wouldn't bother putting one back in. I only run with about half the bolts when I've got my hardtop on, never had a problem.
    Kyle
    89K5
  9. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
  10. Rob 85K5
    1,487
    Pensacola, Florida
    Thanks man, I think that will work great!!
    Rob 85K5
