Topper Seam Filler?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beefcake83, Sep 13, 2001.
  1. beefcake83
    beefcake83 1/2 ton status
    Jun 24, 2000
    240
    Alaska
    Anyone happen to know what type of sealer GM used in the seams on either side of the rear window of the topper. Mine is slowly falling out bit by bit. I want to fill them back up before painting it.
    Gary Graham
    '83 GMC Jimmy 350 'Beefcake'
    Eielson AFB, Alaska
    Metallica & Mountain Dew
    http://community.webshots.com/user/beefcake83
  2. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    I don't know what GM used, but 3M makes several products that you can find at your local automotive paint supply store. They have a line of sealer and adheasives that are paintable, and they are pretty strong also.
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Make sure to use a urethane seam sealer in a caulking type tube. The brush on variety will not fill the seam well, and will crack much sooner.
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
