Topper Vent Window Fasterner Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rolled, May 23, 2004.
  1. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    I spotted a pair of vent windows (or whatever they are called) and the wrecking yard today and I am in need of a pair. I need to know what type of screw/bolt holds them in. From looking at mine, it lloks like there is two screws on the top and bottom.
    I want to bring the minimum number of tools with me so could somebody tell me what tool I need to get these off? Maybe an allen head, phillips, or even a bolt...
    I guess I should have got dirty and climed in to look /forums/images/graemlins/smile.gif
  2. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    Pay for the shipping and you can have mine for free. PM me if you want them...
  3. dyeager535
    26,980
    If you need the window hinges as well, all I can say is good luck.
    This is one of the reasons I ditched the sliders, GM used tiny steel screws to hold that setup together, (at least the to set hinge tension) and since they are screwed into aluminum, every time I tried to remove them, the heads just stripped.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep. Someone screwed the pooch big time when they "designed" that. Hmm, let's connect two dissimilar metals in a place where they are certain to get wet. Once the electrolytic action gets started there ain't no easy way to remove those screws ever again. /forums/images/graemlins/angryfire.gif
  5. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    Thanks for the help guys. I'll test my luck and see if I can get them out, if not, I'll PM you for yours /forums/images/graemlins/smile.gif
    And yes, I need hinges too!
