Topper Window???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ArrowheadK5, Sep 2, 2001.
  1. ArrowheadK5
    ArrowheadK5 1/2 ton status
    Aug 3, 2001
    252
    Northern MN
    I just thought of this, has anyone ever fit a topper window on thier hardtop? So it would swing up instead of sliding down nto the gate? Seems it would be less prone to failure, but I don't know if oyu can bolt/screw stuff to the hardtop or if you couldd find a window to fit.
    Thanks again guys,
    Tom
    Four wheel drive, four wheel expenses...
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    if you know how to work with fiberglass you could do it. you just need to know the properties of glass mat and the resin. what you can and cant do with it. this is a good point. i think as soon as i get some time, TOMORROW MAYBE? i will make a fiberglass properties page. i work with it on aircraft almost everyday. so i will try to help you guys out a bit.
    Grant
    i will put a post up when it is done
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  3. 78Jimmyish
    78Jimmyish 1/2 ton status
    Jul 28, 2001
    137
    Rhode Island
    I don't know about the fiberglass used on the topper, but I work with fiberglass in boats a little bit (I work in the fab/welding shop for a boat company.) It would seem to me that as long as you put a decent sized backing plate on it and thru-bolt through that, you'd be okay - but I'd wait for 74's properties post before you do anything. It'll probably tell you how big a backing plate you'd need to use to distribute the force.
